trouble with net render
A file rendering fine locally isn’t working on net render. I’m using Cache Index and the single cache file is referenced directly through the network in the Input tab. I changed the name of the local cache folder to check I wasn’t accidentally referencing that. no problems there - the local render is also referencing the file on the network. One thing, the cache file is a resim file, but that shouldn’t make any difference right? The file is large (about 1.7GB). Could that be causing the issue?
Panic over.
“Enable Grid Resim” was still checked. Unchecking fixed it.
Whew, glad you solved it!
