Trouble with vray install from zip
Hello, I am installing vray for Houdini for the first time. I am trying to do it from the ZIP file install. Everything seems to work except when I try to run the IPR I get the following error - CreateProcess failed for ‘vfh_ipr -C’. I have rechecked all my environment settings and so forth and all seems to be in order so I am not sure if I have to setup anything else. If anyone has any experience with this problem I would love to know how to resolve it or at least troubleshoot it. I am on Houdini 18.0.391
Thanks!
Must be something with your environment. I would double check so that all is setup as in the readme.
It works for us on both linux and windows.
-- Erik
Thanks, you were totally correct. I went back through my settings and found where I made a mistake. All good now. Thanks for your help.
-Christian
