TROUBLE
Ho guys,
I have this store of which I get pretty good pictures.
But when I sometimes add materials my picture just turns out completely RED. :x Very strange.. I know the blotch stories, but this is something very strange, because I always render a new image after I add a material, I know which material could cause it, yes? So when I again delete the material I just added I also get my red image.. The only way is to completely make your scene a vray material default white and start adding your materials all over. Reset max doesn’t help either. And I always have it when I turn my vraylights from visible to invisible.
I use vraylights IRmap and photon map in second computation.
Good image.
Then I added a wood material to the squares on the door and a chrome material (from the goncalo vray matlib). It could also be a normal material with which I get the red image.
Please help me out here… thx
Nicolaas
1: make sure you have uvw coordinates for all your objects.
2: try checking “apply” in “Cropping/Placement” for all maps!
hope this helps.
is this with the new internal builb ?
i had a problem where max was dropping the textures and vray rendered in a simular fashion… just save and restart max to reload, if thats the problem :wink:
Thx for fast reply…
Anders: I don’t have a UVW map for chrome models… will check it out. About the cropping/placement… will check it out also,…
Natty: How are ya ? Well, it’s 1.09.03n… When I save and reload it doesn’t go away..
Nicolaas
we’ve had blue renderings…seems to be when vray doesnt quite pick up a new bitmap now and then…a rerender seems to solve it…
never had one completely blue/red though :?
Well I have to thank Mr. Anders here… The chrome material needs a UVW map… jeez… Thx man. No probz anymore.. I can turn my vraylight invisible/visible… I knew it was a material question, but one like this jiha..
Thx for everything..
Nicolaas
