I noticed that the rectangle and disk light do not cast true shadows. Instead of a large light plane of light they cast more of a point shadow on objects. Will this be corrected in updates or is there ways to work around this.
I have attached an image for an example. I made a white box up above to show where the rectangle light is located.
As you can see from the columns shadows, they are more of a point light shadow.
Thanks!
