yeah… detail enhancement happens at render time. So what this means is that you can lower the IRmap settings and go get your detail at render time. None of the detail enhancement is being calculated during the IRmap phase, so it is pointless to use it at that time.
Yep, it will cause problems. The irradiance maps calculated with detail enhancement and without it are quite different. If you have calculated the map with detail enhancement “on”, it will contain “blank” areas to be filled with detail during the actual rendering. If you turn off DE for the final rendering, this will look very weird.
thank you, thats what I suspected. I noticed that the irradiance map seemed to take longer with it turned on. But the rendertime itself just became too unmanageable, for an animation at full HD. So I decided to turn it off.
thank you, I know all about vray dirt, I was using it before it was publically released. I also knew what detail enhancement was, just needed to know if it was turned on for an irradiance map, whether you were locked into using it for the render or if a new irrad map would be necessary.
Judging from the responses, Im going to assume nobody else knew the correct answer either, other then vlado.
yes thats one of the problems I have with vray dirt. In certain situations, I have to screen in a local light pass, after multiplying in the dirt, as it basically removed light in corners ans such. Sometimes I just dont want a crapload of passes…lol lazy…
As a person that used renderman for years… I know what you mean. I habitually render a lot of passes then after, I wonder why… with Vray this is need for little more than the beauty pass.
Nope. Like I said in my previous post, irradiance maps computed with and without DE are different. When you render, the DE option *must* be the same as when the irradiance map was computed. Otherwise you will get a wrong result.
haha touche. I guess though, its not nearly that obvious. On the project, where I calced the irrad map with DE turned on, then rendered final without it, I couldn’t really find anything obviously wrong. Of course these were just stills, maybe its more obvious for animations. I rendered a separate dirt pass map along with a lighting pass for it anyways, so maybe not a big deal.
