Submitted on AHA Ideas by Ronald van der Lit (COS-I-1162).
Hi there, you can use the filters in such cases. For example, in Materials category, type “leather” in the search. You’ll see Chaos Scans on top. Then open the Filters and under “Material Type” choose “Standard”. I hope that helps!
Submitted on AHA Ideas.
Hi Tsvetan,
know this is an option, but I have to do it every time I search, and I can’t use scans because I run Corona Solo.
Submitted on AHA Ideas by Ronald van der Lit.
Hi Ronald, are you using the latest version of Corona? With it, you should be able to download and render Chaos Scans materials. With Solo the only limitation is that you cannot edit them. I just wanted to make sure you are aware of that.
As for the issue you are experiencing with the Filters - I’m making a note for that and we’ll think for an improvement. Thank you for reaching out!
AHA Ideas status: Pending.
Set during AHA Ideas to Discourse migration.
