It seems the ability to have the camera turn (stay in same position but look around) in a rendered video has been removed.
I am currently running Enscape 2.2.0.93 on Revit, Sketch and Rhino but my main focus is in Revit.
To recreate the issue :
Create a key frame. > Change where the camera is looking > Create another keyframe.
If the camera doesn’t move it’s x,y,z position but only changes where the camera is looking it seems the new key frame over rides and deletes the previous keyframe
This feature worked in the previous release of Enscape. Am I missing something or has it been removed?
Hi @Vincent_2 This is indeed currently not possible. You can have one position as start and end point of a video, but you can’t perform a rotation.
I’ve forwarded it to our developers.
So currently you have to slightly move the position of the keyframe.
I understand. Thank you!
Unfortunately, that work around does not work in the middle of a walk through because it will just whip from one view point to the next in half a second instead of stopping the cameras motion and just looking around.
Any idea if this is a feature that will be brought back any time soon or is it gone forever?
That’s true, it would only work out as a single sequence with a very slow movement speed.
I presume it will be included soon.
