Turning off clear vfb clears alpha regardless
Hey there,
so just noticed a quirky thing.
Turning off the clear “VFB inbetween renders” option clears the alpha channel regardless. is this intended and can it be fixed? It’s kind of annoying.
scenario:
  1. Render a full image with clear vfb turned off
  2. region render a small section
  3. vfb clears the alpha outside the region area in the vfb
Ouch ! Just discovered this problem at the moment when trying to render part of my image with latest version of Corona. Is this going to be fixed for the next release ?
Thank you.
This should be already fixed in the latest daily build. Give it a try.
Thank you. It does work fine with the daily indeed !
