Turning on area light directional gizmos moves their pivot point!
Just a little annoyance, when you multi select area lights that have directional parameters, if you’ve got the light cone visibility enabled then 3dsmax considers the cone as part of the light’s size when you’re using “use selection center” GUID-564C51A3-3F34-44D5-A6D9-2D506547A762.png(middle one here) and it’ll rotate around the wrong point.
Tiny little thing :slight_smile:
Thanks. The issue is reported as bug in our bug tracker as VMAX-7471. We will notify you, when we have progress on it.
