Turntable/Flyaround?
Feels like the simplest thing to do - how do I create a smooth “fly” around my city model so that it loops (Turntable animation/circle path)
Enscape camera path does the strangest things, zooming in and out on its own if you set 4 keyframes.
Even when I move my model to the Revit origin and use the corners of the Revit view cube it doesn’t work.
Also trying to edit an .xml file did not work.
What is going on here - is this my stupidity or a major flaw in Enscape ?
@Bimtest , it currently requires you to edit the .xml file manually to get something like a real true turntable animation so to speak. You may wanna have a look at this thread here and this thread here as well. In any case, we do have a dedicated feature request on our agenda regarding this subject, so I’ll add your upvote to the state the further demand for this as well. :slight_smile:
Tried but failed…
I got an xml to load (based from an xml in an older thread here:
https://forum.enscape3d.com/index.php?thread/2191-turntable-camera-path/&postID=23095&highlight=turntable#post23095
and also saw all the cameras but then it crashed.
Do you have a newer example file so that I can adjust the numbers ?
(Or has somebody else gotten this to work using the mentioned template )
This really is more painful then it has to be…
I understand now the Y and Z Axis are swapped and can create a circle for the camera path with constant Y value, using the xml.
However no avail in keeping the Focus to a fixed point - resulting in a shaky movement every time.
How is the “look at” value calculated ? This appears to be a point based on the Camera origin; setting it to 0/0/0 does not work.
:frowning:
<?xml version="1.0" ?>
Take a lok at this thread:
Animation
Revit…
