[TUTORIAL] How to export a scene with Ornatrix hair in Vray .vrscene from Maya and render it in 3ds Max?
In this video I show you how to export the created hairstyle Ornatrix Maya/V-Ray Renderer in .vrscene format and render it without Ornatrix - in 3ds Max or Cinema 4D.
Very often - I was asked for such a possibility, because not always clients in the same Cinema4D or 3ds Max - want to buy Ornatrix, and it is necessary to render in it.
In Cinema4D - did not show, because I do not have a V-Ray license for it. But =) The principle is the same. You just select the V-Ray Scene object and load the scene.
By the way, this method allows you to render scenes faster and saves GPU memory. And if you render via Batch, as I showed here - it will be even faster =)
Information about this format - V-Ray for Maya
