Hi guys,
Im trying to use the quixel megascans with V-Ray - I was wandering if you know of any tutorials or guides on how to use them?
Steve
Hi guys,
Steve
Not sure about tutorials/guides but is there any particular bit you’re struggling with?
IIRC you can export from the Megascans Bridge application straight in to 3DS Max with V-Ray materials.
+1. Maybe there is straight export but the results are far from the ones I see on Megascan website.
Hi guys
I founds some good stuff here
1. Corona forum Link
https://corona-renderer.com/forum/in…83703#msg83703
Really good stuff here, they talk about how to convert the secular maps to IOR maps using a LUT. - I cant download the LUT because the link is broken, does anyone have the LUT? - I cant ask for it on the corona forums as I dont have an account.
2. Youtune Channel (Russian + English Sub)
https://www.youtube.com/watch?v=7HJz…HTMkqcxULn1a5M
3. From Quixel Youtube Channel
So I got a full education on that for free! - But I dont understand the Corona thread.
Questions
Q1. Why Are people extracting the IOR from the Spec maps?
Q2. Why Are the megascans looking a little different in V-Ray than they do in the Quixel Mixer?
Q3. Is there a way to match exactly the data sets or is it already matched 1:1 ( I agree with @urbanite , that the rendered results often look far from the assets as seen in Quixel mixer or on the website)
Q4. Does V-Ray have the same IOR problem as seen in the Corona thread?
Steve
Tbh I’ve gotten pretty accurate results from the mixer/bridge to vray. I’ve mostly worked with surfaces. I just export to vray ggx.
YEah its probably a another case of me going a bit too crazy. Ill just accept the results and stop questioning them.
is the max export workign with the new bridge and max 2017? or is it 18 only. cant find the info…
Make sure you are using compact material editor
i yhink you have to install the scripts
I’m on 2016 and it didn’t work for me first time. The previous version did btw. But I recopied the bridge.ms file into the plugins folder and then it was fine. You can also use the slate editor, just browse to the sample slots window.
As another resource, Forest Pack has a great tutorial using Megascans with Vray.
Grant Warwick is showing how to use them in his live streams.
