Tutorials - Importing PDFs, AutoCAD DWGs and image blueprints to 3ds Max + full modelling setup. (3ds Max)
Hey guys!
Recently I published several tutorials about settings up blueprints for modeling in 3ds Max using different sources like PNG\JPEGs, AutoCAD DWGs, and PDFs.
While these are not V-Ray tutorials per se, I think many archviz guys can find it helpful. I hope you don’t mind and find them useful.
Import images to 3ds Max as blueprints for modeling
In this tutorial, Michał will show you how to import design drawings saved as images (PNG, JPG, and other formats) into 3ds Max and set them as blueprints for modeling. On top of that, the tutorial is full of tips tricks that will make your modeling faster!
Learn how to align design levels to 3ds Max coordinate system, organize drawings on layers, align various levels plans to each other, and make sure you don’t need to turn the references on and off constantly when you change views!
Timestamps:
00:00 - Introduction
00:11 - Creating material for references
00:29 - Adding UVW mapping to reference plane
00:42 - Setting the proper display quality of textures in Viewports
01:30 - Setting quality of textures in older versions of 3ds Max
01:54 - Setting correct proportions for the reference texture
02:04 - Setting the size of the reference image
03:33 - Creating separate planes for every view
03:48 - Setting references heights to match 3ds Max coordinate system
04:09 - Aligning sections and plans
04:54 - Setting object properties of reference planes
05:11 - Organizing references with Layer Manager
05:20 - Summary
Import AutoCAD blueprints to 3ds Max like a PRO
In this tutorial, Michal will show you how to import design drawings saved as AutoCAD’s DWGs into 3ds Max and set them as references for modeling architecture - On top of that, the tutorial is full of tips tricks that will make your modeling faster!
Learn how to align design levels to 3ds Max coordinate system, organize drawings on layers, double-check 3ds Max import precision, and make sure you don’t need to turn the references on and off constantly when you change views!
Timestamps:
05:20 - Summary
Import PDF blueprints to 3ds Max like a PRO
In this tutorial, Andrew will show you how to import design drawings saved as AutoCAD’s DWGs into 3ds Max and set them as references for modeling architecture - On top of that, the tutorial is full of tips tricks that will make your modeling faster!
Timestamps:
05:20 - Summary
