3dsmax 2016 … simple scene.. when i lunch 1 more copy of 3dsmax 2016 its like all the selection (faces… objects.. verices…) start to be laggy and slow…
its not the memory. i got 32 gb
i mean even with 2 cubes… when i shut down the extra copy of 3dsmax 2016 its back to be fast again… any idea??
update… its the same on 3dsmax 2017 and with 3dsmax 2014 its all OK… why? any reason ??
thanks
you could try deleting your config, i`ve had issues with that some times.
c:\users\<name>\appdata\local\autodesk\3dsmax\<3dsmax version>\enu
move that folder to desktop(or just delete) and try that ?
sound ok but even if its a fresh installation of say like 3dsmax 2017 did i tried and still its the same thing? its maybe right for old installation no?
Autodesk does not officially support running two copies of 3ds Max. Running two or more copies of 3ds Max can lead to very slow UI, corrupted settings, deadlocks and other issues. For more information, please contact Autodesk directly.
step to check if you have the problem
1 - open max 2016
2 - create some boxes.. convert them to poly
3 - open 1 more copy of max 2016 (empty one in background)
4 - grab 1 box and press 4 to enter to poly mode… keep press off and on … of and on.. its should be fast with no lag…
5 - try to select randomly boxes on the scene… its should select them fast
6 - try to open the customize dialog box.. its should open fast
this is the correct situation
in the unwanted situation all the steps happen slow and lugy… once you shut down the extra copy of max is return to be fast
so vlado… how it can be that all my max 2016 at my home can do it easily and now in my last test even with my old laptop its work like charm with 3 copy of max open…
I’m not the person to answer that question At home I have no problem running two Max’es, but at work as soon as a second copy is up, I can’t get any work done. Like I said, talk to Autodesk about it, there’s nothing that we can help you with.
Just to say that I don’t experience this problem with 2016 or 2017. I can work with quite a few large scenes open. The problem is with the autosave though max saves one of the two open files so if you have any crash it could be costly.
