Two graphics cards, where do I plug the monitor?
Technically you have a monitor plugged into the GPU, but you are not using it. We can’t know if the plugged monitor will be used or not and we always show the warning when there is a monitor plugged into the GPU.
Since your UI and everything is working just fine, you can safely ignore the warning.
