Two instances of max open, but one license?
How is it that I can open a second instance of 3ds max and it can’t find the licensing server but the first instance work just fine?? I’ve been used to working with 2 and sometimes 3 instances open at a time with no issues until today.
Thanks.
You lost connection to the license server - max stays open for 2 hours after dropping it, but new copies opened still check in even if one is open and they won’t pull an extra.
We get our licenses from a server in NYC, and we are in Miami. Happens every now and again.
That’s what I had initially thought. But a check of the licensing server getstatus showed that everything was good. I re-booted and that seems to have fixed the issue. I hadn’t run into that before.
What’s the license server’s version? Try the latest one if you use an older version, I think there was a bug that was causing license skipping in 5.1.0 /5.1.1 when dongles are used.
I’m on 5.2.1 It just did it again, but this time with only one instance of Max 2019.3 running. Restarting Max fixed was the solution.
Can you try https://download.chaosgroup.com/downloads/10148/licenseserver-standalone-522-adv
