Two Point Camera - Named Views
My workstation has recently been updated to Enscape V2.6, and i’m having a problem with two point perspectives, that are named views that previously worked.
The enscape viewport is appear to apply a different lens length so that viewport and enscape aren’t the same.
See screen shot
Running Rhino 6
Enscape 2.6.1+13260
Thanks for your help.
Hi @tbush , welcome to our forums!
To align your Enscape view to your SketchUp view, please enable the view synchronization button:
To export renderings in the same aspect ratio as your SketchUp view, please go to the “Visual Settings” → “Capture” tab, select “Custom” as resolution, and enable “Use Viewport Aspect Ratio”.
Please let me know in case this doesn’t resolve your issues!
I don’t think this option is available in Rhino?
Thanks for getting back to me Kaj, I’m using Rhino not sketchup and as rheinason say dont have the “use viewport aspect ratio”
I have view synchronization turned on, but it not the same lens length, both in the window and the export.
@tbush , @rheinason , I see, both of you - sorry for not checking the top thread properly and assuming you were using SketchUp.
In that case, you are right, we still weren’t successful in synchronizing the viewport aspect ratio and -field of view correctly to Enscape. I took both of your comments and added them to our internal discussion on this topic. Thank you for your feedback!
in my enscape visual settings… I do not have rendering tab..
@AgnesNR , welcome to our Forum.
The tab has been renamed to “Main”. Besides some design changes the options found in that main tab are the same compared to the “Rendering” tab back then.
Let me know in case anything is not entirely clear. :slight_smile:
Hi Kaj Burival,
Has this issue resolved?
I am using Rhino 6 and the latest Enscape version but have the same issue with others.
If I close to object in the Enscape, the camera angle is not the same as the view in Rhino.
It is important issue for me because I am trying to make photomatch view from Enscape.
Has this been solved? I have the same issue with views not matching between Rhino and Enscape in two point perspective. The views are supposed to be synchronized and I am using the same aspect ratio in Enscape output and Rhino viewport
