two points perspective
Is it possible to set a camera that way in VRay.
I do architectural work,and very often I need that option.
Thanks,
Renee
If the camera and camera target are the same height, you produce a 2 point perspective. The Viewport Properties can control a specific viewport. Simply right click on the Viewport name, and then select Viewport Properties.
In your Perspective view, height is controlled by the last set of coordinates (z). I use a height that would reflect a person?s height (about 70").
Thank You.
I know that.What I really need I guess is kind of a tilt or shift lens like the one use on real camera. by photographer to photograph a tower,while standing on the ground and pointing to the top of the tower.Something that correct the parallax.
Thanks for your answer,
Renee
Yes in max there is a plugin for the max camera that can do this. Maybe someone can write it for rhino :slight_smile:
You can also correct this in photoshop with the distort tool, meanwhile
That would be great ! :slight_smile:
But since I can’t do that I will have to rely on a generous somebody else
:slight_smile:
Renee
Can’t do it either, guess you have to bug the rhino newsgroup for something like that. If it is possible, probably it already exists.
