Two Sided material?
Just to warn you, I’m new to rendering in V-Ray. Is there a way to assign a different material on each side of lets say a wall. I want the outside rendered concrete and the interior rendered stucco or something of the sort.
Vray2sided material. Set the translucency colour amount to black so you get no light coming through from one side to the other!
does the wall has no thickness? is it just a single sided plane?
It is an 8" wall
can’t you can use a multi-sub obj mat?
Thanks. Creating a twosided material worked.
or like Rivoli said, just select subobject polys and apply different texture ti inside and outside
or redo the wall with 2 halfs :slight_smile:
