Ok guys.
Here is a basic breakdown of the properties highly glossy materials usually exhibit.
I have created a custom falloff curve for the base coat as a standard fresnel value won’t be as realistic.
WhitePaint_GW.zip (3.97 KB)
Ok guys.
Awesome Grant,
Nicely done!
Stan
I’m definitely all for layered materials in the blend material, though I tend to get slightly more noisy reflections, or longer render times when using it… But I suppose that’s to be expected as after all, you’re using 2 (or more) materials rather than one.
Base coat 256 subdivs
Topcoat 128
Very high sampling but with correct aa threshold renders VERY FAST.
This render took 10 mins, absolutely noise free
What AA threshold did you use for this?
I think I need to start setting my projects with a minimum of 64 samples on materials, and then let the min samples/dmc take care of the rest.
Here it’s not so unsual to have high subds values like those but I’m almost pretty sure my workflow has something wrong so I’m very interested to know what do you Grant (as an expert in shader setup) consider a “correct aa threshold”.
Every new project I try to keep subds with low values but at the end my final solution is always high mat subds values and aa threshold tweaking ![]()
I might be wrong, (and sorry if I spoil your joy of explaining it again grant ;))
but I think this is the thread from Grant explaining his way of viewing DMC :
http://forums.chaosgroup.com/showthread.php?71724-Understanding-DMC-Sampler&p=584178#post584178
Stan
No worries, I take no joy in re-explaining shit haha
I’m curious.
Why does your top coat have to have no fresnel, but blended through a falloff set to fresnel, instead of just setting the coat material to fresnel and blending normally?
Does this actually matter visually, unless you are modulating your blending map with something more complex than the falloff map?
It has a massive difference.
The way you explain will blend between the two materials evenly across the whole material whereas my method only blends the material based on the angle (Which has to manually be tweaked based on what you observe in nature)
Now a real question is, should the top coat still have fresnel enabled (Set to a high value of 12-18 ) and still be blended with a falloff map. I’m not sure what is physically correct, I usually eyeball it.
Maybe I’m breaking reality by not enabling fresnel on the top coat. ALWAYS USE FRESNEL &#^#$&@
Left is my method.
I suppose the best way to approach it is to get down to thinking about what happens to light as it hits the (real world) material. Does it have a top coat? If so, what is it?
If we’re still talking about standard, plain white wall paint, then I’d go as far as to say that it is far, far more simple than all of this. If however you are talking about say… wood with a varnished surface, then you’re definitely along the right path I think.
T.b.h, your example looks wonky. The Blended version suffers from saturation burn and basically just looks like it has a higher IOR than the regular one.
Also, you are approaching some type of metallic effect here, and I was under the impression that we were talking wall paint just recently. That I why I can’t see the use for a layered shader for simple wall paint.
Do you Aussies paint your walls with acrylic and then coat them with a clear shellac after?
The ILM lighting artists I’ve spoken to have said they used this exact method due to the control it gives you and I agree with them, I’ve had more trouble blending mats through eachother than over eachother.
Edit: I’ve spent some time today testing different methods. I still think its best not to use fresnel on the top coat and blend with a fresnel map.
It just doesn’t look right the other way imo.
You don’t get predictable results at all and its impossible to get top coats sitting “over” the surface.
That’s very interesting, Grant, thanks for that. I don’t suppose you could be persuaded to screenshot your VRay render dialog settings and post them here? I think I’ve tried 20 different combinations of DMC settings but I’m still not happy.
Hi All,
I agree Bill, very interesting topic. I’m reading the thread about the sampling right now.
Peter, I’d like to ask you about your workflow if you don’t mind.
Are you saying that beside setting the output to 2.2 you are still correcting all your inputs (colors and textures) manually with a color correct .4545.
Could you elaborate the reasons about it?
I think this is correct but again a big headache when you work on big scale project and with few other people (that are generally used to the LWF from the MAX panel)
Am I wrong or I have seen you using the LWF button in a couple of occasions? One of your tutorial on your blog and a couple of Christmas ago at 3D London @ Hayes Davidson?
I’d like to hear your opinion about it…
Morne, I’ll be interested in reading this article from Lele about setting the output at .25. Are you able to provide a link to the thread?
Regards,
Giacomo.
I remember this, and it was a pain. I had my whole library “corrected” that way. It took my forever to reverse that one it was do longer the fad.
Hi Bobby,
I have just found it.
So you’re saying that this method is obsolete with the latest versions of vray?
Regards,
Giacomo.
might have used the lwf button but that was probably just a quick way of translating an old scene that wasnt set up correctly.
these days I have max gamma ON and use it to correct bitmaps, and then I use vraycolor to adjust all basic colors after hearing Vlado say in Venice that vraycolor was a bit faster than the max color correction map.
Hi Peter,
Thx for your insight.
Do you use the vraycolor on all the maps or just the diffuse? I mean what about the procedurals and gradients? I guess you go back to the color correct…
Regards,
Giacomo.
