I’m finding often the render settings dialogue preference gets corrupted quite a lot with the combo of phoenix and maya, resulting in inaccessible render settings. I’m sure this is a problem with maya rather than phoenix, etc… however the only reason i need the settings is to select the camera from which to preview using the gpu preview. I’m guessing it uses the default vray camera rather than the currently selected camera in the viewport. Is there a way to set the frame size and camera without using the render settings? I can set the frame size in the vray settings node, but sometimes the camera seems to default to the wrong one. Is there another way, rather than resetting my preferences a gazillion times?
Huh, how does ot get corrupted, can you show a screenshot? Does not sound familiar..
Everything is greyed out (see below). Happening almost every time now. I am not using vray shaders (shader fx for previz) I wonder if that is the issue (vray not opening properly but i dont need it, i just want gpu preview). Phoenix is selecting the wrong camera every time and the only way i can select the correct one is to reset the prefs. Is there any other way to ensure the camera i want is used?
It’s happened 4 times now. Desperately need this gpu preview. All i want is to do the gpu preview from the camera in the viewport. But it keeps rendering the perspective camera. Surely there is a way to manually select the correct camera for the preview? I cant get to the render settings - but not even sure if that is the reason why it’s not working. Is there a workaround?
Something is wrong with your maya setup, I’d suggest a reinstall of V-Ray and then Phoenix, and if this does not fix it - Maya, then V-Ray, then Phoenix.
Do you get any errors in your Maya log window? The controls are not greyed out, they are completely missing, so something’s broken in Maya’s user interface.
As for the GPU preview - have you tried setting any other renderer? It has nothing to do with V-Ray - it’s a Phoenix way of visualizing the data, so the viewport size and the camera for the GPU Preview should be taken from Maya, not from the V-Ray settings…
Still having the problem with the sim deleting issue. I play through my sim, select the sim,hit delete, return to frame 0 and it just continues the old sim again from wherever it was.
Oh, you mean without hitting Stop?
No, i stop, then return to zero, and it seems the sim is continuing in the background even when i’ve stopped it…
