u wave / v wave ramp node gpu not working
it appears the u wave and v wave under the noise tab in a vray ramp node is not working on gpu. works as expected on CPU. not sure if this is a limitation for all vray dcc’s
Should mention using latest vray (currently on trial to test it out) and c4d 2024.4
Hello @chris_phillips ,
Thank you for reporting this! It appears that there is missing functionality within the V-Ray Ramp when used with GPU. I have raised this to the corresponding team under request number VGPU-6442. I will keep you informed here of any further progress regarding the matter.
