Uber Noise + VRay Blend
Why doesn’t the OSL Uber Noise map show up in the blend slot of the VRayBlendMtl?
Hi you are correct. For some reason the Uber Noise OSL does not appear in the map slot but nevertheless it works. Tested it in a simple scene - not showing but works and changes the material as expected.
The issue is reported under VMAX-12174.
Below are screengrabs of the test I did - the map does not show up in the slot but works.
This means VRayBlend it not showing output selector correctly.
