UDIM file node + Vray issue
Loading multiple textures (using UDIM tag) works in viewport 2.0 and rendering in mental ray, however when rendering in VRay the texture used is only the first one in the sequence. (File name in file node is cube_diff.<UDIM>.tif)
You could get a newer version of V-Ray or make sure that you have the <UDIM> tag in the file name itself (sometimes Maya only shows the tag there for display purposes, but it’s not in the actual file name).
Thanks Vlado, I just found that keeping the UV Tiling Mode to Off and adding the tag in the Image name solves the issue.
Ok then. For newer versions of V-Ray we’ve made this to work with the uv tiling mode to ON as well.
