UHD Cache Render Button.
Can you add a button that automatically creates a UHD cache. The action of the button could perform setting the job to single frame or every other frame, remove all denoisers, ignore save as output in the common panel, and finally save the UHD to a desired location.
Or better yet, if you make an animation and submit it to Backburner it should automatically make one.
Alex
