How do we increase this number? Mine is constantly giving me around a 12% success rate - precision is on 1
Hi, this is very scene-dependent. For example, if you have a lot of reflective surfaces visible in your scene, this number may be really low, and it is expected.
Ok thanks
12% is super low though. Can you post image of the scene?
is 30% considered low? I’m working on a dusk shot looking across a river at a 8 storey building. All is in shadow put the sun is visible at edge of the frame i.e. backlit.
Noise level has remained on 3.12% from 47 to 50 and now gone up to 3.39% from 50 to 57 passes. Note: I’m also using DBR.
At the moment I’m thinking I probably don’t need 100 passes but I don’t want to stay and watch it.
(It would be good if corona baked more metadata into the exr file, like noise level, render time, camera transformations etc)
Hello there,
I dig this subject up, since I recently started again to take a look at the Success Rate stat, and saw it’s about 26 % … the scene doesn’t seem fancy to me, but I’m wondering if this is expected ?
Using 3dsmax 2021.3, Corona v7 HF1.
Thanks in advance ![]()
Can you please share an archive of your scene with us? Preferably by submitting a ticket, or by simply using Corona Private Uploader:Chaos
Good morning, GeorgeK,
I’m trying to upload the file but the I’m Not a Robot stuff is failing … clicking on multiple pictures never ends ![]()
Using the alternative uploader then, file name: NicolasCaplat_Kitchen_LowSuccessRate.zip, under NDA. At that time, 4 minutes left for uploading.
Thanks in advance,
Regards.
