Unable to bring up VFB when RT is set as renderer
Small annoyance but if the render panel is on the V-RayRT settings it isn’t possible to bring up the V-Ray Frame Buffer inside max. I sort of understand why this would happen - but it doesn’t happen with the Max standard frame buffer.
Cheers,
AJ
That’s correct, I have the same issue here. The “bring to front” doesn’t work, or behave strangely.
