Hello! I’m new to SketchUp and VRay. I’m trying to batch render about 12 scenes. When I click to do so, the software slowly starts going through each scene, but before it ends, it crashes. On VRay asset editor, I enabled save image and chose a location. I also turned off scene transitions. Attached is an image of the error msg I get when it crashes. I would really appreicate any help!! Cami
Hi @camila_mendes ,
Is it possible for you to share the model that you’ve tried batch rendering.
One way to do this is by logging a support ticket using the following link:
https://support.chaos.com/hc/en-us/requests/new
Regards,
Konstantin
Hello @camila_mendes !
Thanks for writing!
We know about this issue, reproducible only on macOS (it is logged in our internal system as SK-5354) and a fix for it will be included in our next V-Ray version.
As a workaround for now - after a render is started, do not close the V-Ray Frame Buffer window. Then the Batch render can be used as meny times as you wish.
Kind regards,
Ivelina
Hi @camila_mendes .
The issue is fixed in our latest V-Ray 7 for SketchUp, Update 2.
Regards,
Ivelina
