Unable to pause animation in Enscape 3.0
Hi There!
I’m trying to create an animation in Enscape and at some point, I would like the camera to ‘pause’ at one point for a second or two before moving on to the next keyframe.
I used to be able to overlap two keyframe and adjust the timestamp to create that pausing effect in previous version, however in ver. 3.0 it doesn’t let me edit the timestamp.
Sometimes I use the same method to create timelapse effect as well but with the new version I can’t do that anymore
Is there another way out there?
Hey @BRENDENLOH , welcome to our Forum, and thanks for your post.
At least right now, you will have to ever so slightly move one of the cameras which are overlapping in the two keyframes - then, save the new location of the camera and you should be able to adjust the timestamp of both. There might be a very slight camera movement in the final video since you moved the camera, of course, but it shouldn’t be that noticeable.
