Unable to place Enscape Assets, Archicad21
Hi. This is the second project where this error has occurred, both in Archicad21.
The problem: I choose my tree, try to place it in 3D, nothing happens. Earlier in the day i was able to place the assets (trees, cars..).
/////// I just figured out the solution. I’m dealing with Teamwork projects and Enscape creates a folder in the Embedded Library, if that folder isn’t reserved the problem above will persist. It would be great if enscape would prompt you to reserve the folder if it needs it :wink: :slight_smile:
Hey @davidstone , thank you very much for your feedback and welcome to our forum. :slight_smile:
We’re generally aware of this behavior when Teamwork is involved, we’re working on a fix for this which will be implemented as soon as possible.
If there is anything else I can help you with let me know!
