CPU:5950X
corona version: 7.2, 8.0
Several cpu stress tests were performed, including C4D physics, standard renderer can be rendered at full load.
need help
Did you run the Corona benchmark? Corona Benchmark | Chaos
Compare your results with other 5950X
Could you please share some screenshots of your scene project?
Do you have the “rendering threads limit” option enabled on C4D prefs?
Regards.
I don’t know
Maybe I found the bug
Provide my project file, is extremely simple scenario
This is the only such
All others are default settings
原.c4d (1.63 MB)
this is most likely caused by “Adaptivity” (This switch is located in “Development/Experimental stuff” in render settings - To see this tab, you need to allow Preferences>Corona>Enable devel/debug mode first).
You can read up on adaptivity more in https://support.corona-renderer.com/hc/en-us/articles/4402704757009-What-is-adaptivity-
For a scene like yours, it may be valuable to turn off adaptivity.
Thanks,
Jan
