I just upgraded to 1.5 and it doesn’t appear I can render out animation sequences, it will only render out whatever frame is currently being viewed in the timeline for the duration of the timeline is. When you hit play or scrub through the timeline it shows the animated camera as normal.
I reverted back to 1.43 and everything works as expected so it doesn’t appear to be a camera issue.
I’m not sure if this is the same issue, but after installing version 1.5, I can’t see the mentioned “Live Link animation render button” in the Vantage toolbar.
I also can’t see the “Chaos Vantage” category in the Customize User Interface / Toolbars / Category dropdown.
If I search for “Vantage” commands in 3ds max by hitting “X” it does not show any commands either.
Yes, this will be resolved when you update V-Ray for 3ds Max. The new update will be released very soon.
The issue in this thread is regarding rendering out a sequence within Vantage itself, not via Live Link. It might be worth starting another thread for that particular issue.
