Hi
I can’t figure out how to save assets library favourites. I just unable to rich the star on top left to set a bookmark. Is it any secret with this or keyboard shortcut?
Hi
Hey @A3D , thanks a lot for your post and welcome to our forum! ![]()
You should be able to just click the little star on the top left to mark any Asset you like as Favorite. In the first instance, could you kindly make sure you’re running our latest release of Enscape? Check out how to make sure you’re up to date here.
In case that doesn’t help, which CAD solution are you using Enscape with and do you generally have any problems with your mouse what so ever, as in, selecting anything/clicking and so on? It would be great if you could also send in some feedback as described here to receive further information about your machine as well as log files.
Thanks a lot in advance!
@Stephan_1 and @A3D , could you kindly let me know if you have the Asset Library window close to the edge of your screen or if the problem can be fixed by moving the window / changing the window size? Thanks in advance!
The screenshot was made in de middle of my screen.
When i put the asset library window to the edge of the screen, only the first row on the left is now correct and posible to click on the star.
When it is on fullscreen it does not work.
