I’m trying to get back into 3ds Max with Corona renderer so bear with me if my questions are a little elementary.
I have a building in a scene and I added a Corona sun, 2 Corona Cameras, and an environment sky in the sun modify panel. During an interactive render, using the corona camera view, my render is super bright.
My first thought was to change the sun’s intensity but that did very little, (even after lowering it as low as it will go), So my next thought was to change the camera shutter speed and F Stop.
Neither of those settings made much difference. My scene is still blown out bright. I applied a generic Corona physical material to everything in the scene so it’s all white as expected. But super over exposed.
Sun/Sky is modeled after physical intensities so you’ll need to decrease exposure.
In the VFB:
- either use the ‘Simple exposure’ operator, which is the default mode, and lower it to your liking. Simple exposure works globally in the VFB, it will not take the camera’s exposure settings into account.
- or use a ‘Physical exposure’ operator (add it using the ‘+’ button in the operator list), this one takes into account the camera’s settings and adopts its exposure depending on the camera used for rendering in the VFB.
You can use both at the same. Just keep in mind that simple exposure will be always applied, on top of your physical/camera based exposure.
Generally it is not advisable to change sun’s intensity too much since it’s set to physically accurate value by default. What you probably want is to change exposure of your view/camera. Again, by default exposure control is set to simple, not photographic, so changing camera parameters like F-stop, ISO or shutter speed won’t have much effect on your scene. The easiest way for you to fix that overexposure issue would be to open render setup, navigate to camera tab and press edit tone mapping button. You then decrease simple exposure spinner until your scene is normally exposed.
