Do you use any other plugins (multiscatter etc)? I don’t get this here, so if you can get me a scene, no matter how simple, it will also be useful to figure out what’s going on.
I gave it a couple of days and the issue hasn’t re-appeared so far. The only plugin I was using was Npower Power Translators. I’ll post back if it occurs again and investigate further. Thanks for your replies.
AHHHH… getting the same thing. I am using forest pro in the scene… also my proxies were not showing up. I installed 22001 / reinstalled 21001 and the error is still there. Scene was fine last night. Frustrated.
So I got everything back working, but with 2.10.01 and the Forest 3.7.2… now I am Leary to upgrade. itoo said that they tested it with 2.2.00.1. Any one else having issues with the update?
Not exactly, we are using Forest 3.7.3 with VRay 2.20.00.2, not .00.1. Also this version of Forest was compiled with the latest SDK (.00.2) . Instead, for v.3.7.2 we used VRay 2.0 SP1.
Anyways, in our tests, v.3.7.3 works fine with both VRay versions (2.0 SP1 and 2.20.00.2), so i don’t know what may be the problem.
According to my IT guy, there was an HTML character in my directory root folder “middle dot” and this was causing the errors. looks like this. “D:\ckowal\Rendering\•ANN_Prod”
