What does this error mean and what could be causing it?
Vray Next for SketchUp | CPU+GPU Cuda
Ryzen7 1700@3.6Ghz
RTX 2070
GTX 1060 6GB
16 GB RAM
Using Standalone with a .vrscene file, I get this error from time to time, when trying to render animation (239 frames). It’s not predictable when it will happen.
I think this is also the same issue causing SketchUp to BugSplat when I’m rendering there?
EDIT:
I was using version 40001. Is this a known bug for vray 40001, which is fixed in 40002?
This was happening with Build 9bc354be from Jan 31 2019, 18:47:20
I now installed Build ebb382a1 from Mar 5 2019, 18:35:18, but haven’t tried it yet.
sorta hard to tell without knowing a bit more info. But I would guess your running out of vram. Do you have task manager open at time of rendering and happen to notice what your available vram is at when it fails?
Hi Joey145,
I would like to ask first of all , does this error appear only for this particular scene or it occurs with others as well.
I would suggest that you update to V-Ray 40002 and check if the Unhandled Exception still appears and if it does, does it still happen if you reset your render settings ?
If you’re still experiencing issues please send us the file at support@chaosgroup.com using a file-sharing service of your choice in order for us to investigate the problem further.
Best Regards ,
Assya
