It may be a VRay bug. I remember having the same results with an earlier version of VRay. I conducted further investigation now with 3.40.03 and Max 2016
You may have to read through this more than once to understand what I’m on about.
So, when I get to a stage when the Material displays correctly in the material editor, but Double Gammad in the viewport, I instance the diffuse texture from the material that is not displayng correctly in the viewport, and instance the diffuse to a new STANDARD material and also a NEW VRaymtl. I tried with both new materials without re-running the script, and then like magic, the viewport displays correctly. If I then apply the original material again (still without running the script), the viewport again displays double gammad. (Even though the new and old material is identical)
So I wonder if instead of just assinging the values, which they may already have, I should do a bunch of “if then” or “case of” checks and see what the current values are, and if they’re not what it’s suppose to be, only then set it to the correct value.
Makes no sense as it’s just extra code because
a = 1
a = 1
a = 1
basically says a is 1 (a will always be 1 even if you assing it 1 again)
Just trying to think out the box here because it’s a VERY WEIRD issue
If I take the material that displays correctly in mateditor, but double gamma in viewport, make a copy of the entire material by just dragging the ball to another slot and assign it, it’s fixed. If I then apply the original material again, broken
Hahaha twilight zone
Thanks AJ, The issue occurs with all scenes and is not scene dependant. I’m going to be modifying my code with a bunch of if statements and see how that goes. If it still doesn’t work, I’ll send you a PM and we can take it from there.
