Unit B
This one turned out good, or so I think :). It rendered in 45 minutes using IPR, with some quick post color grading.
I rendering a 2nd time with RT GPU+CPU and I let it render for the same amount time using the same settings and they turned out the same, as far as noise goes. With progressive render the denoiser worked good enough that I could use it as a final (see above image), however, that wasn’t the case with RT. Plus, the RT reflections were not very good. I have one GTX1080ti, which has 11GB of RAM.
Interested to see both one next to the other (CPU rendering and GPU rendering).
when I get time I’ll do that.
