It’s the first time i get these message on Backburner with Universal V-Ray settings. I was rendering large size for print (3600px wide) on a Quad Xeon.
The task restarted twice after every 10 hours. it didn’t crash or anything but just restarted… is it the BB or Vray’s doing it? anyone know?
It’s a well know issue of backburner (release 3 if I remember correct)
make a search in AREA forum, I saw a lot of threads there
update your backburner to 3.02 may be a solution ..or u can try to edit manually your backburner.xml to force global timeout
a.
PS
for sure it’s NOT vray related except for the fact that is vray that takes more than 10 hours to render
PPS
use VRIMG for that large size image otherwise after solving your timeout problem your quad will render fine but will not save the final image (no more RAM) or 3Gb switch or x64 with 4 Gb
