is something wrong with my installed update or is it a bug? (I called the command from the V-Ray menu.)
Is the toolbar the latest version?
-Micha
Hi Micha,
I don’t understand what the problem is here?
There is no vrayInstancer command available.
The Scatter command (if that’s what you’re after) is vrayScatter.
As far as the toolbar is concerned - there are some items missing.
Here’s what you should see:
You can try restoring the Rhino toolbars.
Note that Rhino is sometimes doing that - it stores a cache for the toolbars and does not show the correct one when a new plugin version is installed.
Hope that helps,
Konstantin
I found the old post with the save toolbar refresh and it works now. ![]()
Yes, exactly.
That’s what I was just about to share.
