Unknown problem
Hi all, may i know what is this happen?
Anything weird going on in your environment/effects tab? hotkey 8 Maybe exposure control is on for MR or something weird?
Seems related to a camera. Try deleting and making a new one?
Hi Deflaminis, thank you for your reply, i have check and nothing is on in environment/effect, but i am rendering the file with backburner.
This only happen to all the slave when render with DR.
Anyway, i will check back the file see whether is there any problem with the camera.
Does it appear if you render it locally with/without DR?
Hi svetlozar.draganov, this message didn’t appear if render using local pc without slave, it appeared in slave machine only.
Did i do anything wrong?
Is there any hardware difference between the workstation and slave machines, especially in the amount of installed RAM?
What is the exact version/service pack of V-Ray/3DSMax and OS?
Is the issue scene dependent, does it occur on every scene or just on particular ones?
