Can you try going to that folder C:\Program Files\Autodesk\3ds Max 2016\scripts\startup\ and removing the CoronaRenderer_InitScripts.ms file? Then install Corona again, and see if it helped.
If not, I would recommend reinstalling 3ds Max.
reinstalling corona did not help. Further more; i got an 3ds max application has stopped working everytime. Disabling some service got me in 3dsmax but then I got the error in the startup maxscript.
Now I’ve removed the script from my startup folder and max starts up perfectly.
Saw in the code some legacy stuff being removed and so on… so I figured, once it has done that it should not be started again..
