- unkown property "classID" in undefined
I have a problem with my scene while network-rendering with backburner.
It’s not problem to render the scene directly from max. If i try to render this thing with backburner the following error occurs:
“- unkown property “classID” in undefined”
The same scene renders fine on all other pcs in the network. This error only happens on two workstations :frowning:
Any idea?
thanks,
filip
classid errors usually point to missing plugins. Did you double check that ?
Regards,
Thorsten
