Right now when you animate an object in Max , I mean animate transforms parameters like move , rotate, scale and hten export the aniamted object in vantgae standalone, then in vantage you cannot move it inside the scene.
when you move it inside vantage when you hit play the object goes to its initial position
can you fix this , so that we can create animated libraries of doors opening… that we can just drag and drop in our scenes
Second That!!!
Appears to have changed from 2.3 to 2.4 where you can’t relocate animated objects inside vantage - they always snap back to origin in .vrscene
It was VERY helpful to be able to setup looped animations for objects and save those to a library that could be added/placed in vantage scenes…
For instance I have a library of animated pool planes, foliage and other misc. objects that I used to be able to easily add to vantage scenes
… but now that’s all locked to .vrscene
Exactly!!!
I think though that deforming animation like water animated with noise, modifier can still be relocated in vantage.
animation of position ,rotattion , scale is now locked!!!
thanks a lot for mentioning that the change happened from 2.4 on!!!
I don’t think we have changed anything in 2.4 compared to 2.3 that could have affected this.
This has always been the case.
Can you provide an example that worked in 2.3 but doesn’t work in 2.4 ?
Greetings,
Vladimir Nedev
Dear Vladimir
You are right,
Yesterday I installed all previous versions of Vantage and none worked.
BUT nevertheless can you please fix this, or at least leave this as default but give us a possibility to enable relocate animated vrscenes.
This is very very important, for anima 4d , renderpeople 4D and whatever animation preset we create!.
Can you please explain why it is default that you cannot relocate animated vrscenes
Thanks a lot in advance
It’s just somewhat difficult to implement an additional transform on top of the vrscene animation.
Greetings,
Vladimir Nedev
