Unlocked Highlight and reflection glossiness error
So with Next and older materials when I get the error about “Unlocked Highlight and reflection glossiness” is there a way to edit the material so I don’t get this error or do I have to remake my entire material library? 90% of my materials had this unlocked and there are a couple hundred of them which kinda sucks if I have to go through and recreate them all again.
-dave
90% of your materials? How old are those materials? I guess it’s time to give them an update :-). I’ve never unlocked this in my 10 years of visualization actually.
https://forums.chaosgroup.com/forum/…he-hglossiness
Thanks for the link. Looks like Im screwed then lol. Some materials are old-ish but then again Ive been doing this, lets say for a number of years before V-Ray hit the scene :wink:
-dave
when I get this error, I just convert scene with native vray scene converter, and errors were solved ..
Nice to know, I thought about trying that. Might give it a shot on a test scene and see how it goes.
Thank you.
Strange thing, I’m getting this issue AFTER running the VRay scene converter. It seems like the scene converter is UN-locking the highlight glossiness. Is anyone else getting this?
This is true unfortunately. V-Ray Scene converter is not yet updated and it indeed unlocks the highlight glossiness. We are working on this right now, it should be fixed for the next service pack.
We’ll see also what would be the best way to handle old materials, maybe we can make the converter to automatically locks their glossiness.
Where are you at with this. Has it been corrected? I have some scenes that I ought to convert I suppose to get rid of this error message.
Quick fix:
theMats = getclassinstances vrayMtl
for m = 1 to theMats.count do
    theMats[m].reflection_lockGlossiness = on
Eh, not quite.
It will make the warning go away, but the look of the shaders may turn out *quite* different depending on how the two components were driven.
To anyone but the shader author is nigh impossible to figure out what should have precedence over what, so my suggestion is to bring those shaders up to date manually, just to make sure it’s done in the right way.
You and your professionalism :stuck_out_tongue:
Ahahah, no but really!
Since i started working here, the pressure of getting little things like these wrong has been *enormous*.
By comparison, my TD time in film or viz was carefree. ^^
Sorry for projecting, hey! :stuck_out_tongue:
Ha! Sounds ideal to be surrounded by people that drag you upwards - you were already starting from a fairly lofty height too :wink:
he talks. ^^
Hi there, sorry to revive and old thread, but I’m getting the same error messages.
The shaders are old vray shaders, I locked the highlights to get rid of the error message, and fixed the highlights etc, but the error message won’t go away.
The only way to get rid of it was to manualy rebuild the shader from scratch and match the settings. Not fun times :wink:
Using vray next, and 3dsmax 2019
did you try and run a v-ray scene converter?
It should get those fixed.
Yes if time is a constraint I too have been using the V-Ray scene converter.
If I do have the time then I have a new material library where I recreated all of my old standard or most common materials like chrome, stainless steel, and other basic materials and using that, I go through the scene and change out all the materials with the new ones I re-created.
Given the problems I’ve run in to lately with V-Ray and 3ds max and some other scripts/plug-ins, I have trust issued with any kind of automated tools lately and prefer to do a lot manually like using the materials I recreated, as I believe Lele suggested above as the better option as well.
Cheers,
-dave
@Syclone1 @_Lele
Hi, I have a similar problem with old demo scenes.
Question: After you exchanged the Materials into new ones, how did you get rid of the old nodes with “unlocked highlight and glossiness”?
As far as I know there is no “delete unused nodes” in Max.
Or any other tips on this topic?
Many thanks,
Ben
Did you run the V-Ray scene converter on those scenes?
It should fix that kind of stuff automagically.
joconnels script don´t work here, but this did the job:
for m in getclassinstances vrayMtl do m.reflection_lockGlossiness = true
Greetings
