i need to make some render to texture files with unpremultiplied alpha channel. I could not find any checkbox at the render settings to make the alpha unpremultiplied. I already set IF to “none” but there is still image filtering…
I may be wrong, but I think the most important thing here is how the software you are opening your file in interprets opacity. You can easily render an image with alpha channel with nice opacity effects and antialiased edges, and then open it in the right application, and change background to anything you wish, without any artifacts and stuff like that.
