Unusual render flaw
I’m experiencing some odd flaws in the render phase.
on matirialed texture popping up something that looks like a bobble
notice the columns in the image below
Re: Unusual render flaw
Thats probably something due to very bright pixels. In Color Mapping, check Clamp Output and SubPixel Mapping. That should help out
Clamp Output, SubPixel Mapping
i’m not familiar with those concepts :'(, could you please explain (1. where ???, 2. how ???)
Its in the Color Mapping rollout in the V-Ray Options.
Clamp Output limits all of the colors so that none of them are brighter than white. This can help sometimes when working with bright aspects within a scene (the sun being the typical reason).
SubPixel Mapping basically calculates whether a given pixel is brighter than white as it takes the samples. This means that it won’t oversample a pixel when its already too bright and will also make the end result smoother.
Thank you Dalomar
