I am experimenting with Corona - trying to incorporate it into my main workflow as it is excellent at first glance. Most ‘issues’ I have had are solved by a little bit of research on my part, but I cannot figure this one out. My image exhibits small shadow lines around certain objects and details around the ceiling (see attached) - an effect very similar to the Ambient Occlusion option in Vray that can be embedded into the render - only I cannot find any option to control this in Corona. I’ve tried various plain materials to the same effect.
The image is 1500x1500px and around 900 passes - the areas highlighted in red on the attachment are the problem areas.
Is the same material applied to wall and ceiling parts? I would bet either on displacement as Romullus suggested, or reflectivity. Can you disable both and see what happens?
I’m asking about size of your scene not a units. For example is your table 100cm or 10000cm tall? You should always work as close to real world scale as you can.
Ok, so I solved it. Or rather I discovered and deleted a vray light and some vray materials hidden in the scene a long way from the camera, but it seems they were understandably messing with Corona’s calculations.
But thank you very much for the help - I really do appreciate it!
