Hi, I am events designer and have been using Enscape for Sketchup for a number of years. I keep having issues with my renders. The images come out grainy and I am struggeling to resolve this. Below are some images that might explain my issue
copied to new project
I turn sunlight to 0 and use black skybox and the problem is back
Any ideas on how to resolve this would be great! Many thanks, Oli
Hey @olidesign_1 , thanks a lot for your report. Can you clarify which Enscape version you are using (you can find that info in the About window)?
In case this is the latest v3.5.6 release: In this case there’s unfortunately a known issue with usually very bright scenes. Two options that you can do to avoid this noise in this case:
- Reduce the (sun & artificial) light brightness in the visual settings and see if that resolves it
- Disable the “Nvidia Denoiser” in your renderer settings.
If it’s not 3.5.6 or the above didn’t help, then the problem is likely rooted in the scene setup with the entirely black skybox. It seems that the noise isn’t visible in the setup with the default sky.
Instead of using the black skybox I’d recommend using the mask export feature to have an image without the background and just change the day-time to night for your renderings.
Hi Clemens,
many thanks for your reply! I changed the Skybox file and now it seems to be working!!! Here is the 1st Skybox image I used, which produced the noise in the renders
And this is the new one
here is the result with the same lights and textures as originally
I hope this will help understand the issue! If it happens again I will explore your suggestions and let you know, many thanks, Oli
