Up: materialconverter script
Ok, on the old board i posted an topic with the request for help on scripting an converter… you got an batchconverter which doesn’t work fine enough to post it on the new board again.
Here we have an alternative:
I changed the maxscript from neil belvis converter to accept vray materials.
www.cgtechniques.com/~upload/chris/maxscript/single_vray_converter05.zip
easy to use: extract both scripts into your max/scripts folder and start the “single_converter05.ms” script. The other script is a library.. don’t rename it.
Select the slot with the std-mtl and convert it.
IMPORTANT: you have to put the material to the scene again… it’s a not scriptable function.
Thing’s which doesn’t work:
converting settings from the vraymap.
:smile:
Much obliged Dschaga,
will work with it and post any bugs. Time to start converting those old scenes.
Hughg
